U-Boot > printenv
baudrate=115200
boot_fdt=try
bootcmd=mmc dev ${mmcdev};if mmc rescan; then if run loadbootscript; then run bootscript; else if run loaduimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi
bootdelay=1
bootscript=echo Running bootscript from mmc ...; source
console=ttymxc0
ethact=FEC
ethprime=FEC
fdt_addr=0x18000000
fdt_file=imx6q-sabresd.dtb
fdt_high=0xffffffff
initrd_high=0xffffffff
ip_dyn=yes
loadaddr=0x12000000
loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}
loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}
mmcargs=setenv bootargs console=${console},${baudrate} ${mmcroot} ${video}
mmcboot=echo Booting from mmc ...; run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootm ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootm; else ec;
mmcdev=2
mmcpart=1
mmcroot=root=/dev/mmcblk1p2 rootwait rw
netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${uimage}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if;
script=boot.scr
uimage=uImage
update_sd_firmware=if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; if mmc dev ${mmcdev}; then if ${get_cmd} ${update_sd_firmware_filename}; then setexpr fw_sz ${filesize} / 0x200i
video=video=mxcfb1[biggrin]ev=ldb,LDB-XGA,if=RGB666 video=mxcfb0[biggrin]ev=hdmi,1920x1080M@60 video=mxcfb1[redface]ff video=mxcfb2[redface]ff fbmem=28M consoleblank=0
Environment size: 2053/8188 bytes
root@imx6qsabresd:~# fdisk /dev/mmcblk1
The number of cylinders for this disk is set to 481280.
There is nothing wrong with that, but this is larger than 1024,
and could in certain setups cause problems with:
1) software that runs at boot time (e.g., old versions of LILO)
2) booting and partitioning software from other OSs
(e.g., DOS FDISK, OS/2 FDISK)
Command (m for help): p
Disk /dev/mmcblk1: 15.7 GB, 15770583040 bytes
4 heads, 16 sectors/track, 481280 cylinders
Units = cylinders of 64 * 512 = 32768 bytes
Device Boot Start End Blocks Id System
/dev/mmcblk1p1 * 65 192 4096 c Win95 FAT32 (LBA)
/dev/mmcblk1p2 193 481280 15394816 83 Linux
U-Boot 2013.10 (Mar 20 2014 - 08:28:12)
CPU: Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: WDOG
Board: MX6-SabreSD
DRAM: 1 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
MMC: no card present
MMC init failed
Using default environment
auto-detected panel HDMI
Display: HDMI (1024x768)
In: serial
Out: serial
Err: serial
Net: Phy not found
PHY reset timed out
FEC [PRIME]
Warning: failed to set MAC address
Hit any key to stop autoboot: 0
mmc1(part 0) is current device
U-Boot > setenv ethaddr 1E:ED:19:27:1A:B3
U-Boot > setenv autoload no
U-Boot > dhcp
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Retry count exceeded; starting again
Abort
U-Boot > printenv
autoload=no
baudrate=115200
boot_fdt=try
bootcmd=mmc dev ${mmcdev};if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootenv; then run importbootenv;fi;echo ;
bootdelay=1
console=ttymxc0,115200
ethact=FEC
ethaddr=1E:ED:19:27:1A:B3
ethprime=FEC
fdt_addr=0x11000000
fdt_high=0xffffffff
importbootenv=echo Importing environment from mmc (uEnv.txt)...; env import -t ${loadaddr} ${filesize}
ip_dyn=yes
loadaddr=0x12000000
loadbootenv=load mmc ${mmcdev}:${mmcpart} ${loadaddr} uEnv.txt;
loadfdt=load mmc ${mmcdev}:${mmcpart} ${fdt_addr} /dtbs/${fdt_file}
loadzimage=load mmc ${mmcdev}:${mmcpart} ${loadaddr} zImage
mmcargs=setenv bootargs console=${console}${optargs} root=${mmcroot} rootfstype=${mmcrootfstype} video=${video}
mmcboot=echo Booting from mmc ...; run mmcargs; bootz ${loadaddr} - ${fdt_addr};
mmcdefault=echo Booting from mmc ...; run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootm;
mmcdev=1
mmcpart=1
mmcroot=/dev/mmcblk0p2 ro
mmcrootfstype=ext4 rootwait fixrtc
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_;
script=boot.scr
uimage=uImage
update_sd_firmware=if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; if mmc dev ${mmcdev}; then if ${geti
Environment size: 2486/8188 bytes
U-Boot > setenv mmcdev 3
U-Boot > boot
MMC Device 3 not found
no mmc device at slot 3
U-Boot > setenv mmcdev 0
U-Boot > boot
Card did not respond to voltage select!
mmc0(part 0) is current device
U-Boot > setenv mmcdev 1
U-Boot > boot
U
