Getstream_a84 and Getstream-fta [Linux package]
Postby gfi » Sat May 04, 2013 12:27 pm
Getstream_a84 [opkg package] and getstream_fta
Getsream_a84
Homepage: https://bitbucket.org/cesbo/getstream_a84/wiki/Home
Getstream
Homepage: http://silicon-verl.de/home/flo/projects/streaming/
Standard version for http/udp/rtp streaming (icluded glib2, libevent libraries).
Note: Tou need to have installed an opkg manager (viewtopic.php?f=95&t=8485)
1.
Over ssh type:
opkg install getstream-moi.ipk
2.
You can control installation with:
opkg list
3.
type:
getstream -c <config_file>
You can remove package with command:
opkg remove Moi-package-getstream
getstream (fta version):
unpack attachment and place gstream to /usr/bin directory.
Don't forget to chmod 755
Note: Very low cpu load in idle state - FTA version. You can add ECM/EMM pid manually to Your config file and decode it on client box/app.
getstream-fta.zip
(25.9 KiB) Downloaded 608 times
getstream_a84.zip
(529.55 KiB) Downloaded 632 times
gfi
Re: Getstream [Linux package]
Postby Haronych » Mon Oct 14, 2013 2:20 pm
"The selected attachment does not exist anymore."
Please fix it !
Haronych
Postby gfi » Wed Nov 13, 2013 1:30 am
Haronych Wrote:"The selected attachment does not exist anymore."
Please fix it !
Fixed
gfi
Return to Software
