Home > Products > TBS TV Tuner PCIe > DVB-S2X > TBS6903 Professional DVB-S2 Dual Tuner PCIe Card
    TBS6903 is a Professional level digital satellite TV Tuner card with PCI Express interface. TBS6903 not only supports normal DVB-S2/DVB-S QPSK, 8PSK which is supported by normal satellite receivers, but also supports CCM, ACM, VCM, 16APSK, 32APSK, Multiple Transport Stream, Multiple Generic Stream, Combined Single Generic &Single TS, which most satellite receiving devices can’t support. With use of dedicated TBS tools, those special streams can be captured. The two advanced DVB-S2/S tuners enable you to watch TV channel from one satellite transponder, while recording channels from different satellite transponders of another tuner at the same time.
    • EUMETCast Compatibility
    • DVB-S2/S dual tuner
    • CCM, VCM, ACM and Multi Input Stream support
    • Generic stream mode Support
    • Blind scan support
    • EPG (Electronic Program Guide) support
    • Unicable/one cable compatible
    • Data receiving
    • Media monitoring
