TBS8510 is a real-time SPTS/MPTS transcoder, which supports converting media files from their source format into the best possible quality stream to downstream network, CDN or any other specific video distribution system.
TBS8510 supports multiple media resource input, capable of ingesting IP feeds, DVB feeds, ATSC feeds, ISDB-T feeds or HDMI videos. It supports converting streams to MPEG-4 or H.264/H.265 format, compressing the streams' bit rate, changing the graphics resolution and so on.
TBS8510 can be easily managed through NMS system and has become an ideal solution for operators to provide high quality video transcoding.
TBS8510 Transcoder is upgraded to Kylone V3 transcoding system
Overview of the "Web page playing function"
Once the video stream is output from TBS8510 transcoder in HLS protocol, users can easily watch/preview the video by appointing URL in browser or scan a QR code via smartphone or smart Pad.
Input the URL in browser to preview the stream or watch the video. | Scan QR code by smart phone or smart Pad to preview the stream |
TBS8510 currently has 3 hardware versions to meet various system's requirements:
Version 1 supports installation of 2 TBS DVB/ATSC/ISDB-T capturing cards (up to 16 tuners) for receiving signals from DVB/ATSC/ISDB-T. It supports transcoding up to 30 HD or 60-80 SD channels.
Version 2 only supports IP stream input, not available to be installed with any TBS tuner card. It supports transcoding up to 40 HD or 80-100 SD channels.
Version 3 supports installation of 2pcs TBS DVB-C/DVB-T modulator cards (up to 8 frequencies) for converting IP streams to DVB-C or DVB-T signals and output via RF ports. It supports to output of up to 360Mbps DVB-C signal or 217Mbps DVB-T signal
Every version of the TBS8510 transcoder has the following features and specifications:
Application:
