- TBS6909 is a powerful DVB-S2 octa tuner card with PCI Express interface, capable of receiving SD/HD digital TV channels from 8 different transponders simultaneously, which is considered as a pr... more >>
- TBS6902 PCI-E DVB-S2 Dual Tuner TV card is a PCI Express interface digital satellite TV Tuner card for watching and recording Free to Air satellite TV on desktop PC. With two tuners, the TBS690... more >>
- TBS6903 is a Professional level digital satellite TV Tuner card with PCI Express interface. TBS6903 not only supports normal DVB-S2/DVB-S QPSK, 8PSK which is supported by normal satellite recei... more >>
- TBS6904SE is the successor of TBS6904, it not only supports to receive SD/HD digital TV channels from 4 different satellite transponders simultaneously, but also supports VCM, which is consider... more >>
- TBS6908 is a Professional level digital satellite TV Tuner card with PCI Express interface. TBS6908 supports not only normal DVB-S2/DVB-S QPSK, 8PSK which is supported by normal satellite recei... more >>
- TBS6910 DVB-S2 Dual Tuner Dual CI PCIe Card is a twin tuner digital satellite TV for watching or recording two different channels from two different frequencies simultaneously. You can use one ... more >>
- TBS6910SE DVB-S2X/S2 Dual Tuner Dual CI PCIe Card is a twin tuner digital satellite TV for watching or recording two different channels from two different frequencies simultaneously, it also su... more >>
- TBS6928SE, the successor of TBS6928, is a PCI Express (PCIe) interface digital satellite TV Tuner card for watching and recording digital satellite TV on PC. With integrated CI slot, it can be ... more >>
