MOI Pro MAX is a new professional IPTV streaming server powered by Intel Quad Core solution. It can be loaded with 4pcs DVB TV Tuner PCIe cards to receive live TV signal and stream the channels through Ethernet. With pre-installed Kylone streaming software, MOI Pro MAX provides more possibilities to IPTV system integrators and TV service operators.
Kylone software is designed by TBSDTV and is compatible with all TBS DVB tuner/modulator/ capture cards. It offers a comprehensive set of tools and features to empower users in efficiently organizing digital TV broadcasting service across cable, satellite, terrestrial and IP networks with advanced real-time monitoring. With Kylone, you can manage all your DVB sources. Know more details, please check https://www.tbsiptv.com/kylone-digital-content-managing-panel
Key Features:
What is the difference between TBS2951 MOI Pro AMD and TBS2952 MOI Pro Max
TBS2951 | TBS2952 | |
CPU | AMD® G-Series SoC GX-420GL (Quad Core, 2GHz) 15W | Intel® Embedded Celeron J6412 (Quad Core, 2.6GHz) 10W |
SSD | 30G SSD (mSATA) | 250G SSD (M.2 SATA 2242) |
RAM | 4G DDR3-1600 | 8G DDR4-2666 (Support upto 32G) |
LAN | 2x1Gbps | 1x2.5Gbps+1x1Gbps +1x1Gbps (Optional) |
PCIE | 4*1xPCIE share with 2*PCIE 2.0 | 4*1xPCIE with 4*PCIE 3.0(Independence) |
System | CentOS7 | Rocky8 |
Software | Tvheadend, DVBlast, MuMudvb… | Kylone (Preinstalled) |
Input | DVB-S/S2/S2x, DVBT/T2, DVBC/C2, ATSC, ISDB-T, DTMB, HDMI, ASI, | DVB-S/S2/S2x, DVBT/T2, DVBC/C2, ATSC, ISDB-T, DTMB, HDMI, ASI, UDP(Unicast,Multicast), HTTP, HLS, RTSP, SRT, MPTS, Local TS File |
Output | HTTP, UDP | HTTP, UDP, RTP, HLS, SRT, SPTS, MPTS |
