Home > Products > TBS TV Tuner USB > DTMB > TBS5210 DTMB TV Tuner USB Box
    TBS5210 is an external DTMB TV tuner card with USB2.0 interface. It's ideal for watching SD and HD channels on your PC.
    Through the USB interface, you can easily plug the TBS5210 DTMB TV Tuner into your desktop or laptop PC. With appropriate signal cable connected and software installed, it's convenient to receive DTMB channels.
    TBS5210 can also serve as a digital video recorder for recording digital terrestrial multimedia TV programs with full HDTV support. The Time-shifting function allows you to pause a live broadcast and continue from where you left. TBS5210 is ready with Windows BDA driver and Linux driver.
    Features
    • DTMB single tuner
    • Watch & record DTMB TV /radio programs on PC
    • Real-time signal quality monitoring
    • High-definition video, real-Time and scheduled video recording
    • Windows BDA driver and Linux Driver are ready.
    • High reliability design, stable operation
    Applications
    • Data receiving
    • IPTV streaming
    • Media monitoring
    Model NO. TBS5210
    Model Name DTMB TV Tuner USB Box
    Connection USB2.0
    1x RF IN
    DTMB Signal
    DTMB(GB20600- 2006) Supported
    QAM Mode 16QAM, 64QAM
    Bandwidth 6M/7M/8M
    Frequency Range 100M~858M
    Signal Level -1 dBm ~-81dBm
    General Spec.
    Input / Power 2W
    Operating Temperature 0 ~ 60 °C
    System Requirements Windows XP / Vista/ 7/8/10/11, Linux
    Available USB 2.0 slot
    Dimension
    TV Tuner Card Size 9x 7.5x 2.5 cm
    Net Weight 120g
    Gift Box Size 220 * 130 * 30mm
    Weight 350g
    Package Contents 1x TBS5210
    1 x USB Cable
    1x F-IEC
