Home > Products > Encoding card > HDMI > TBS6302X 4K 30Hz Dual HDMI input Encoding Card
    TBS6302X 4K Dual HDMI Capture Card
    TBS6302X is a high and standard definition capture & 4K encoding card with dual HDMI 1.4 inputs, it being capable of max 3840 x 2160P@30fps input and H.265 & H.264 encoding. It is an ideal device for whom need to stream lower bit rate video over LAN or WAN networks – often due to internal network limitations, whilst maintaining high quality video.
    After capturing UHD/HD video from HDMI ports, TBS6302X will generate H.264/H.265-encoded stream in TS packet and output via PCIe connection. TBS6302X can be used as a normal DVB Tuner PCIe card, so it will stream the video to network by many DVB streaming software, like "DVBLast", "TVheadend", "Astra Cesbo" in Linux. TBS6302X is equipped with 2 HDMI 1.4 inputs. The PCIe interface allows users to install TBS6302X into any full-profile PCIe slot, including fixed workstations such as 2U or 4U rack-mounted servers or media centers.
    • IPTV Servers
    • Datacasting and monitoring
    • Live TV Capture and streaming
    • Broadcast TV
    • Dual HDMI 1.4a input, HDCP 1.4 is supported
    • Capable of max 3840 x 2160p@30fps input and 3840x2160p@30fps encode
    • Supports H.265/HEVC and H.264/AVC Video hardware encoding, AAC-LC/AAC-HE Audio encoding
    • With the support of DVB streaming software , support to stream the video in several different protocols simultaneously
    • Support to be applied to various IPTV system in the industries of education, health care, conference, news interview, and so on
    • Supports OSD overlay: insert logo, text
    • DVB Architecture, compatible with DVB software
    With TBS encoded setting tool, it can easily switch between channels and adjust configurations.
    Linux Platform: command line control
    Windows Platform: GUI setting tool
    Specification:
    Input 2x HDMI 1.4a, HDCP 1.4 supported
    Video Input 3840x2160p_30hz, 1920x1080p_60/50/30/25/24hz, 1920x1080i_60/50hz
    1280x720p_60/50hz, 720x576p/i, 720x480p/i, and etc.
    Encode Size 3840x2160, 2560x1600, 2560x1440, 2048x1152, 1920x1080, 1680x1056, 1280x720, 1024x576,720x576, 720x480, 704x576, 640x480, 640x360, auto
    Video output 3840x2160p@30fps, 2560x1600p@30fps, 2560x1440p@30fps, 2048x1152@30fps, 1920x1080p@60/50/30/25/24fps, 1280x720p@60/50/30/25fps, 1024x576p@60/50fps, 720x576p@60/50fps, 720x480p@60/50fps, 704x576p@60/50fps, 640x480p@60/50fps and etc
    Video Codec H.264/H.265
    H.265: Main
    Bitrate Control CBR/VBR/EVBR
    Frame rate 5~60fps
    Key Interval (gop) 5~180fps
    GOP Structure IPPP
    Bitrate 300~20000Kbps
    Color depth 8 bit
    Chroma subsampling 4:2:0
    De-interlace Supported. Force to do de-interlace when i (interlace) input
    Audio Input HDMI embedded
    Audio Codec AAC-LC, AAC-HE, MP2
    Audio Bitrate 24/32/44.1/48/64/96/128/160/192/256Kbps
    Audio Resample 48k, 44.1k, 32k
    Slot PCIe 1x
    Control Linux command line, Windows GUI setting tool
    Driver Windows Driver 64-bit, 32-bit OS; Linux driver
    Application Compatible with DVB software: Windows platform: DVBream, DVBviewer, and etc. Linux platform: DVBlast, Tvheadend, Astra Cesbo and ect.
    Power Consumption 6.6 Watt
    Net Weight 170g
    Working Environment
    • Operating temperature: 0 to 40 deg C
    • Storage temperature: –20 to 70 deg C
    • Relative Humidity: 5% to 90% (non-condensing)
